メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
I accidentally broke the battery socket.
Hey guys, when I was replacing my battery, I accidentally broke the battery socket. I don’t know if this is a generic socket and find it anywhere which I could not found it yet.
Can you help me out? Where can I buy this or is there a specific socket name for that?
I have searched the following keywords but no success.
  • PCB battery/power socket
  • Logic board battery socket
  • A1707 battery socket.
  • Macbook pro logic board battery socket …
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
ベストアンサー
I’ve not yet repaired any 2017 Touch bar yet, but I’m pretty sure that’s much too small to be the battery connector. I’d suggest you add a wider field picture to figure out exactly what that is. However, Apple is strongly trying their best to not let any third party repair their boards lately, they’re even preventing chips they use on their boards to be found in the market just in case a few hundred bucks can slip away from their greed chain, thus you won’t be able to find a replacement part for sale anywhere. Your best chance is to try to find a dead board on eBay and get your part from it. Or, sad but true, replace your logic board because of a 2 cents worth pure plastic part.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
@arbaman - Thats the batteries sensor cable. It looks like the connector broke free from the solder joints so its possible someone could re-attach it (someone with good micro-soldering skills)
さんによる
@danj I surely agree if the connector didn't get ruined or lost.
さんによる
Pads aren't ripped so the connector that was ripped off should be re-usuable as long as the plastic is not broken. Definitely worth fixing as most reputable macbook board repair stores can fix this.
さんによる
@benjamen50 I know it's a 15mins job _if_you have the part. This one too would be an hour job, but it seems parts are nowhere available: https://www.youtube.com/watch?v=gmRd9IVE...
さんによる
コメントを追加
This would be a simple repair relatively. Sadly since this is much later it won’t help you but anyone who sees this. You’ll need some soldering skills and a microscope. That is cable transfers data between battery and board and will not function properly without it. It’s best to find a professional near you who has experience dealing with delicate electronics at a microscopic level.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Commenting much later. Broke the plastic connector that “locks” it into place today while changing my thermal paste on my mid 2017 mbp and the battery is undetectable now. Thanks for the answers! Got much clarity now.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Firat Agdas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,280
