メインコンテンツにスキップ
モデル番号A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 プロセッサ
330回答 すべてを表示
iMac Display shows horizontal bars/lines
My iMac started to show strange horizontal bars (perfectly dividing the screen into 4 areas), with flickering lines. The colors of these bars are blue/black.
Adjusting the brightness cause the bars get less or more visible.
Replaced my HDD with an SSD 6 months ago without issues until now. I was reading about opening the iMac and damaging the LCD display connectors.
The display works perfectly when it’s connected to an external monitor, wired or via airplay.
Did any kind of tests, even Apple Service Diagnostics, no issues found.
Thanks in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
What does an external display look like? If its clean then the display assembly is damaged, it the external show the same markings then the logic board has problems.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
As mentioned in my post, the external display shows a perfect image. Can you be more specific about the display assembly please? What is damaged specifically, the whole LCD? Thx
さんによる
Sounds like it was damaged in the process of taking it off then. Most of the time one see's bars when the display was not taken off correctly using the proper tools and technique. Here's the needed part [リンクされた製品が存在しない、もしくは無効: IF174-035] and here's the guide to replace it.
さんによる
I did the SSD replacement myself following the iMac Intel 27インチ EMC 2546ハードディスクドライブの交換 guide and bought the same kit. Are you sure it's not possibly related with the display data cable, or it's connectors?
I'm asking to be sure because changing the whole LCD is really expensive, also idk why doesn't shows to be available for international shipping when I try to add to my cart (
さんによる
If you strongly believe the cable and or the connectors are damaged then lets take some pics so we can see and post them here.
The T-CON board on the back of the display is where I suspect your problem is located. As an example : 27" 2014 iMac T-CON board.
さんによる
I agree, but no, I cannot be sure. I will ask to iFixt if there some possibility to ship internationally the Display Assembly. Thanks Dan!
さんによる
3件以上のコメントを表示
コメントを追加
Since you can connect to an external monitor IMHO I think you are correct. It sounds like the LCD display connectors have been damaged. I’ve never repaired/replaced that but perhaps the iFixIt archives will have something? Good luck.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yep, saw some. I guess I have no other way to open and try. Thx.
さんによる
コメントを追加
I seem to have the same issue. iMac screen is messed up but “clears up” after some time. Hooked up to external monitor no problem.
Brought my machine to Apple and they couldn’t 100 Percent give an answer. Computer is in working order except for the mysterious screen issue that comes and goes.
Nobody knows what to do.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yep! Your internal displays T-CON board is failing!
Sadly, you'll need a new display iMac 27" LCD Display Panel & Front Glass Assembly (12/13) and here's the guide you'll need to follow iMac Intel 27インチ EMC 2546 ディスプレイ交換
さんによる
コメントを追加
回答を追加する
BVox さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 1,806
