メインコンテンツにスキップ
対象のモデルはA1419 / EMC 2806 / Late 2014 または Mid 2015。 3.3 または 3.5GHz Core i5 または 4.0GHz Core i7 (機種ID iMac15,1)、EMC 2834 late 2015 / 3.3 または 3.5 GHz Core i5 または 4.0 GHz Core i7 (機種ID iMac17,1)のRetina 5Kディスプレイを搭載したすべて。
573回答 すべてを表示
iMac 27 late 2015 CPU upgrade with i7-6700?
I know you can upgrade the late 2015 iMac 27 with the i7-6700K. But I can get a i7-6700 for much cheaper that the i7-6700K.
Has anyone tried it?
Thanks
p.s. I know the iMac is difficult to open. Already did it many times before.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Did you find any solution for this? I’m also looking to a 6700.
さんによる
@kim_sv yes, it’s working - tried it today
さんによる
コメントを追加
2件の回答
最も参考になった回答
If you already went through the very stressful process of opening and disassembling the unit the CPU replacement shouldn't be a problem. I did it myself though I've used the 6700K - can't see why the 6700 wouldn't work after al my unit had the 6600 (not the unlocked K).
One thing though: the spring that holds the heatsink in place can be a very difficult thing to put back and maybe even damage your CPU - ANY CPU if you're not careful enough.
I recommend ‘flatten’ it a bit using a plier or whatever you can. It should still work as to hold the heatsink in place but if it is too strong that you have to push down very hard (and I am quite a strong person…) you should definitely ‘flatten’ it or you WILL damage you CPU. Check the CPU replacement guide and read the comments on step 62 - you'll see I'm not the only one who had a problem with that:
iMac Intel 27インチ Retina 5Kディスプレイ CPUの交換
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Tried it, it’s working and running @3,4ghz
Update (21.09.2021)
see attached picture for proof :)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
mollocampo さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 56
今までの合計 4,121
