Samsung tab pro sm-t525
Hello,
i have a samsung tab pro sm-t525.
device charge bad so i replace 2x the charging port and the batterij but still same problem.
device stops charging after 2-3 min.
vdb consulting since you already changed the battery and the USB connector (hopefully it is a good repair and the parts are functioning normally) you want to go ahead and check the charging circuitry according to the schematic
このアンサーは役に立ちましたか?
Then it’s probably a battery issue here is the replacement.Samsung Galaxy Tab Pro 10.1 Battery Replacement
このアンサーは役に立ちましたか?
No, we change the battery also, no result..
Stops everytime with charging
Did you get them from a good place like ifixit?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 242
