メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Released on July 28, 2014, the Samsung Galaxy S5 mini is a cell phone that features an 8 MP rear camera, 720p display, fingerprint scanner, and water resistance. It has a larger display, increased battery life, and an updated camera from its older brother, the Galaxy S5.
Is it necessary to clean inside of my phone if it is fall into toilet?
My mobile phone was dropped in toilet for 12 hours. I dried my phone. But i think there is dust inside. But my phone is running very well. I want to know if the dust is harmful for the future?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Hi @fixzahid ,
Water resistant doesn't necessarily mean waterproof.
The specs state that it can withstand water up to 1 metre for 30 minutes, which is a bit different to 12 hours submerged!
Whilst there are no problems for now that is not to say that they won't appear in the near future.
Just so that you are aware of this
Personally I would open it up to inspect it but I'm just cautious around electronics and water especially if the device is not new.
Are there any minute cracks in the case or flaws in the seal due to normal activity over time which may have compromised its’ water resistant integrity for example?
Here’s a link to the ifixit Samsung Galaxy S5 Mini guide, if you decide to do this
This link may also be of some help. Electronics Water Damage
Hopefully you also cleaned the outside of the phone appropriately given where it was found submerged and also how the phone is used ;-)
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If your phone is running very well, then there is no need to fix anything for now. Samsung Galaxy S5 phones are water-resistant, so being submerged underwater probably didn’t cause significant damage.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I feared about the dust,not the water. Will dust create any problem?
さんによる
The mechanism in the phone that blocks the water will most likely block the dust as well.
さんによる
コメントを追加
Yes its highly recommended you can run in to a lot of issues from it.
If I helped you please accept my answer回答の承認方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Zahidul Nahid さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 23
今までの合計 384
