メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年6月発売。モデル番号はA3003(EU)、A3000(中国と北米)。(以下の情報より https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
Won't boot after LCD replacement.
Dear IFixIt community
After replacing my LCD my one plus 3 wont boot.
When I plug it into the wall, it does charge and the LCD powers on with the battery charging icon. Vibration working and everything. But when pressing the power button, it won’t power on.
Could this be a problem with the volume buttons & lock buttons failing? How do I check that it is that and not a faulty motherboard/daughterboard?
Kind regards and thank you
Axel
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
If you replaced it ( you opened it up) open it again and check the connections you messed with it could be the battery isn't fully connected as you should disconnect during a repair to avoid damage from power still being in the board. If someone else replaced it (paid a shop or company) take it back and have them fix it. It should be free for them to fix it as they broke that part of the phone or failed to repair it properly and should honor they're work.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Dead mister Parrish
I did the repair myself.
I just checked the battery, it is fully connected and pushed it again. Still with no luck.
I don't think the problem is with the battery, as it does charge and show up on the LCD when plugging in, it just won't power up. So my best guess is that the buttons are broken.
Thanks for your answer!
Kind regards
Axel
Any Idea on how I could check that?
さんによる
While your in there take a look and see if the silicone dome for the button has been moved or fell out during the repair. And try to short that contact to force the board into thinking the power button was pressed. If shorting the button works then something is missing or damaged if it doesn't work then your problems lie elsewhere.
さんによる
Hey Sean
Thanks again for your answer.
Seems like the phone was botting, but the screen seems to be studdering, going on and off when I hold it in a sertain position. This was happening before I fixed the screen.
I did check all the contacts, could this mean a dead motherboard/daughterboard?
Is there any way to check what is broken or what is not?
Thanks agian.
Axel
さんによる
コメントを追加
Before changing my display of my oneplus 3t phone was working fine no battery issues. But after changing display my battery percentage is stuck at 0% and it's not moving up My phone is working perfectly fine when plugged in with the charger. But switches off when charger is removed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Axel D'Olislager さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 671
