メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
874回答 すべてを表示
Battery drains from 40 to 25% and than in a few seconds to 1%-0%
Hello,
I have problem with my iPhone 8 battery. Since housing and charging port replacement, my iPhone starts to turn off randomly, even if battery percentage was 70%. I thought, that an original battery was damaged during the process (which surely was), so I decided to buy a new one. After replacement, everything seems to be OK, phone works perfectly at 100-50%, but around 50%, battery very fast drops to 40, then drops to 25% in a few seconds and then drops to 1% and 0%.
Should I try to replace battery again?
Where could be the problem?
Thank you for all your answers.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Most likely pry damage near screen / battery connector on the logic board. Perhaps some small IC components may have gotten knocked off or damaged when the cables were unplugged.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Is there some way, how to find out, where is the problem and try to fix it?
さんによる
Look around the battery and screen connectors...look for anything that is damaged or missing. Magnification is preferable.
If you see anything damaged or missing, then it will require a micro-soldering repair.
さんによる
I did that today with magnifying glass and everything seems to be perfectly fine. No damage or broken parts at all.
さんによる
コメントを追加
If you have a Mac, download and run Coconut Battery to get a much better picture of the condition of this battery.
https://www.coconut-flavour.com/coconutb...
Post an image of your results, please.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Thank you for answer. I dont have Mac, I am Windows user. Is there app like this for Windows?
さんによる
Here are three alternatives for Windows users : https://coconutbattery.en.softonic.com/w...
さんによる
And what exactly I should look at in these apps?
さんによる
さんによる
コメントを追加
回答を追加する
Andrej Pracovný účet さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 11
今までの合計 154
