メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 sometimes not ringing with iOS9
So my Problem is with iOS9, that my iPhone 6 is sometimes not ringing. Its sporadic and - i think - only with Numbers, that are in the Call History or under Contacts, then the iPhone is only vibrating verry short for one time, the Display is dark and it makes no noise. If i press the Home Button i can see who calls me.
So i think it must be a Bug, because in 95% everything works fine and with iOS 8.XX i never had this issue.
When i tried to reproduce the Problem, i called my self a few times and sometimes it was ringing normally, and a few time i had the issue that there was only a short vibration with a turned off display.
I reseted all Settings a few times, but it did not help. Anyone had the same Issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Try resetting the phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If your calls are malfunctioning but the rest of your phone works fine, then the problem may be your calling app. Please see if these fixes won’t help-
  1. Try uninstalling and then reinstalling the phone call app. Doing this will also update the app.
  2. Try using a different app for phone calls.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
roroeow7 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 72
