Why windows is not turn on (no response)
i have n150 plus that do not turn on i replace the ram but nothing i saw that power led and chrging is turn on but no loading
If your power LED light is coming on, then your power supply is working.
But if nothing is showing up on your screen, here are a few fixes you can try:
If these fixes don’t work, please tell us what was happening before the problem occurred that may have caused it. Maybe some background information can help us help you better.
このアンサーは役に立ちましたか?
It's possible the RAM he is using is not compatible with his system? That could cause some problems. Great comment about checking for beeps.
i have the original ram installed in the pc
so what can i do in this?
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 8
過去 30 日: 47
今までの合計 400
Have you tried putting the original RAM back in your system to see if it will boot correctly?
Carlos Oulman さんによる
