メインコンテンツにスキップ
Samsung netbook with a 10.1" screen and 1.66 GHz Intel Atom N450 processor.
Why windows is not turn on (no response)
i have n150 plus that do not turn on i replace the ram but nothing i saw that power led and chrging is turn on but no loading
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Have you tried putting the original RAM back in your system to see if it will boot correctly?
さんによる
コメントを追加
2件の回答
If your power LED light is coming on, then your power supply is working.
But if nothing is showing up on your screen, here are a few fixes you can try:
  1. Check your computer’s brightness settings. Are they turned all the way up?
  2. Check for beeps or error messages. These codes may contain clues as to what’s wrong.
  3. Check your hardware. Are all the cables inside the computer secure? Is your video card in the slot securely? Is the RAM that you added in the slot securely? Try re-seating all your RAM, cards, and cables.
  4. The problem may be your software. If the screen is blank because there is a problem with Windows itself, you may need to reformat your hard drive and reinstall Windows.
If these fixes don’t work, please tell us what was happening before the problem occurred that may have caused it. Maybe some background information can help us help you better.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It's possible the RAM he is using is not compatible with his system? That could cause some problems. Great comment about checking for beeps.
さんによる
コメントを追加
i have the original ram installed in the pc
so what can i do in this?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
osher1446 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 176
