メインコンテンツにスキップ
RCA Android tablet, identified by model number RCA RCT6303W87.
37回答 すべてを表示
RCA Pro12 Missing Storage and USB Settings Menu - Marsmallow
Hi There.
Just wondering if anyone else out there has encountered a similar problem,
I recently purchased a RCA Pro12 Tablet on ebay.
When I received it I noticed a large sticker underneath reading "Demo Unit-Not all features might be fully activated" or something along those lines
Everything seemed to be working fine though, that is, until I decided to install a SD card into the unit for some added storage space.
It does not want to "see" any sd cards I insert into it, but even more than that, when I go to it's settings menu, I cannot find an option for "Storage and USB" anywhere under the settings menu???
(It does however recognise usb sticks plugged into it on it's usb port)
I have googled far and wide, but so far not come across a similar problem on the RCA tablets (or Android 6) out there, so I must admit, i am now completely stumped!
Any ideas as to what to try to get it to recognise sd cards, or to let the "Storage and USb" options appear again under it's settings menu?
Oh yes, it is running android 6. (Marshmallow)
Many Thanks,
Gary
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
I would say fresh format it with normal OS…I can imagine that because its a demo unit it was to prevent people from loading malicious software in via the SD Card slot.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Makes sense.
Next big question would be, would out there maybe happen to know where one would be able to obtain the original (non-demo) firmware?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Just googling Fresh Firmware install for your tablet name but you could try factory reset to see if that fixes it?
さんによる
コメントを追加
回答を追加する
Gary Megit さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 126
