メインコンテンツにスキップ
モデル番号A1706/EMC 3017ー2016年11月発売。この13インチのMac Book ProはOLED Touch Bar搭載です。デュアルコア"Skylake" Intel Core i5 CPUと4つのThunderbolt 3ポートが特徴です。
239回答 すべてを表示
2016 MBP Touch Bar cannot be charged and is now dead.
My laptop had always been perfectly working well until three days ago it could not be charged anymore and it is now dead. I watched a two-hour long film with full charge at beginning but the battery went down to 27% when the film ended. I was very shock, so I started charging it. But it the battery percentage did not go up but kept dropping until it was totally out of power. Then I tried to charge it overnight. In the morning when I work up I found that it was still out of power. Then I tried another charger through different ports on the laptop, it still did not work.
Then I sent it to Apple Store. The technician used his charger to try to boost it but failed. He then told me the worst case is that the logic board could be damaged. He said as the SSD is soldered into the logic board on the 2016 MBP, so the data will be lost if the logic board needs to be replaced.
There were some important files in my laptop without backup. I really need to take all data out. I am wondering A) how likely is the logic board damaged in my case and B) is there a way to get my data out intact?
I am yearning to hearing a voice which would make me less worried cos I am really really worried.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I received my laptop from the Apple Store. The logic board was replaced and the data was gone. They said they tried many times to transfer the data from the damaged board to the new board via their specialised data recovery tool but it did not work on my laptop. I did not receive their ring but an email saying my laptop was ready to pick up without explaining anything. Then when I came up to them, they brought a totally new machine back to me.
さんによる
Did they do it for free?
I'm sorry your data was lost.
さんによる
コメントを追加
2件の回答
ベストアンサー
Boy I love Genius’s that just don’t know their stuff ;-{
Your data can be recovered! There is a special tool that Apple has to do this This is Apple’s special tool to help customers recover data from the MacBook Pro’s non-removable SSD
Go back to the Apple Store and show them the document and ask they use it to recover the files. Sadly, you’ll need to buy a replacement logic board and you should bring a external drive so they have something to copy your data too.
Let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
So how do WE get this tool? @kyle
さんによる
@mayer - The 2016 & 2017 models need this tool, the 2018 doesn't offer recovery as far as I know. So far none of the T2 systems do if the board is dead. If you enable access via the security setting you can access the drive via Target Disk Mode. But, that needs to be set before you need the access!
さんによる
コメントを追加
The apple bar guys will make you sh** your pants like you are a little boy. Why trust these guys I am not sure. The data is recoverable even if the board is dead. Worse case scenario, if the ports are not able to read, can still remove the flash chips to read them manually but will cost $$$$.
The logic board may have the power control mux issue. The boards includes 4 of these chips to manage the power supply and they are made by Intersil (Maxim). I hope you are using the apple original charger and cable. The aftermarket chargers got issue with the current control and some times the pins are different.
I don’t think the logic is trash by your explanation and should be able to fix without so much hassle.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
@freewill - You can't remove the soldered flash chips and then expect to recover the data it's not that simple! No one has the needed gear to do that. And I'm sure no one is willing to swap out the chips of a good system to even try.
The issue is first recovery of the data and then the systems logic board can be looked at more fully.
Not many people have the skills & parts to fix the logic board outside of Apple. Louis Rossmann is one of the few. But even he can't always pull a rabbit out of the hat if something deeper is wrong.
さんによる
@danj I am not Louis Rossman and I don't get on YT to blah blah to show the simple fixes. I only posted one or two video how to rebuild the ME region and some BS. I don't have intention to make money with something I can teach others for free so I don't bother to buy the microscope camera and set up to show how to fix very basic things like I am building a rocket.
So you don't know me nor know what I do but said like I am a rookie because I posted on iFixIt. Check the site www.hakintosh.com but the contact email is disabled due to many distractions with stupid questions.
さんによる
コメントを追加
回答を追加する
Oliver Zhang さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 947
