メインコンテンツにスキップ
2018年7月に発売された15インチMacBook Proです。モデル番号はA1989です。15.4インチ LED-Backlightディスプレイ、True Toneテクノロジ、TouchIDと最大6 Core i9プロセッサを搭載しています。
209回答 すべてを表示
Will my touchbar go out?
I dropped my charger on the end of my touchbar and its kind of dead towards the end. Will the whole thing go out before i can get it fixed? How much would this repair cost? Im trying not to press so hard on it or slam the screen down. Everything still works even Siri even though you cant see it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Well good news! You don’t need to replace the uppercase at all, you only need to replace the TouchBar its self!
MacBook Pro 15" Retina (Late 2016-2017) Touch Bar Assembly
Its still a big job so you might want to find someone better skilled.
MacBook Pro 15" Retina (Late 2016-2017) Touch Bar Assemblyの画像
製品
$39.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hello,
Shortly : no it shouldn’t break even more. The Touch Bar is attached to the keyboard, so Apple will change the battery, keyboard and Touch Bar (the hole bottom assembly of your Mac actually). This should cost around 600$. From what I see in your photo, and from what you say (it still works), I don’t think paying for a replacement would be a great idea. Wait for your keyboard to get stuck (keys can get stuck easily on these models), and let Apple repair it for free (they repair this issue for free, changing the hole bottom part, so the Touch Bar also).
You can find the keyboard free repair program here : https://www.apple.com/support/keyboard-s...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@talerant - I don't see Apple fixing this for free, unless Keja got AppleCare + and they will still charge a fee as it was damaged, not a parts failure even if the keyboard fails at some point, they will argue the keys got damaged at the same point.
さんによる
コメントを追加
回答を追加する
Keja Wynn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 147
