メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
Does ultrasonic cleaning PCBs turn liquid damage indicators red?
Many repair technicians I’ve read recommend thoroughly cleaning PCBs using an ultrasonic cleaner with Branson Ultrasonic Cleaning Solution mixed with water. It sounds like good advise, except many Apple PCBs have liquid damage indicators. Wouldn’t the water content in the cleaning solution turn them red?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Of course it will turn the LSI red when they get wet.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It can! It depends on the cleaner. They are designed to fire off from water.
Frankly, I rarely use an ultrasonic cleaner on a logic board. It’s only if the board has corrosion or a residue (liquid damage).
I use a Rechargeable Air Sprayer which I load with different solutions depending on what I’m dealing with. This allows me to focus the cleaning Vs doing the whole board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
From what I’ve experienced through Apple, they don’t actually do a lot of ‘repairs’.
They can definitely diagnose and replace components, but in terms of circuit level components, they just up and replace everything with a new part. They call these ‘Depot Repairs’.
If you actually pay apple to fix liquid damage on your board, they will not even mess with any ultrasonic. They may not even have such machines in a Genius Bar (I can not verify that statement).
So what you are asking doesn’t apply to Apple, so you have to use the thinking of, the indicator was already tripped when something was spilled. Your use of ultrasonic will mark that it was repaired properly.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@snakes202 - Apple does not do component level repairs (never have in the stores or the repair depot locations) and they also don't fix liquid damaged devices when they see either obvious damage and/or wet markers have changed.
The way AppleGuyPie asked it's not clear if he is dealing with a liquid damaged logic board or just thinks ultrasonic cleaning is a SOP for any repair.
さんによる
コメントを追加
回答を追加する
AppleGuyPie さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 15
今までの合計 326
