メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
After screen replacement, water damaged 6s screen not turning on
This may be a long one, so strap in.
My 6s was water damaged about a week ago- all indicators have turned pink. I was listening to music, and had flashlight on so I’m fairly certain something was shorted when water came in. I had a waterproof case on that failed, so it wasn’t a complete flood, just enough to shut down the phone.
Music turned off, lines appeared on the screen, then screen went dark and finally flashlight turned off. I was not able to shut the phone down before it died, itself.
I opened it up, and stuck it in a bowl of rice hoping it would work a few days later, but didn’t. I decided to keep it on charge because in my mind, if the battery was already screwed, then why would it matter?
However, I was still able to feel the vibrations from phone calls and see the light towards the top of the screen (not sure what it’s called) through another device’s camera, so I knew it was on.
I just replaced the screen, hoping that was the issue but still nothing. I can see the light through a camera, but I haven’t tried calling the device.
Am I correct in suspecting it’s something on the motherboard or logic board? Is this phone even salvageable?
Also, not sure if it’s relevant, but about two months ago I replaced the factory Apple battery and cracked screen with parts from iFixit.
I don’t have a lot to spend at the moment, and this phone is how I make money. The other device is an iPod touch 4th Gen, so it can’t run the apps I need.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You will need to perform a water damage repair on your phone, remove the logic board and clean it in an ultrasonic cleaner, then try a new battery and lighting connector. To be honest this should have been done before your phone completely shut down. Take it to a local repair shop, if you don’t have an extra battery, lighting connector, and ultrasonic cleaner.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Will the cost in parts/labor outweigh the value of the phone?
さんによる
コメントを追加
回答を追加する
Cameron M さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 43
