メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
no display on iPhone 6
hey guys, i replaced screen/digitizer on iphone 6. all good. i carefully put it into a REALLY tight cover. all ok. few days later i had it out to show that cover. that night was in a hurry and kind of mashed it into that cover. never lit up again. it had a very dim light, no display, just very dim. i ordered another screen/digitizer but still the same. this cover is very good, just really dam tight getting it in. what could i have done to disconnect this display.?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Unless the cover is so tight it can bend the iPhone housing, it might be just a coincidence too. When lifting the connectors for replacement it may happen to damage components surrounding them. Issue might be related to the backlight circuit as well as a damage to your new screen. If you still have around the old one I’d try the replacement to check first if it’s a screen damage. If it’s not a screen damage it would probably be on the board itself and would require microsoldering skills.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
john さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 34
