メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Replacement Screen goes blank when waken from idle/timeout.
I wonder if anybody can give me a pointer as to what is going wrong my replacement screen for an iphone 6s, when I installed the screen i can get it only to work when the screen is popped out and has no pressure on a certain area of the screen.Once the screen is placed into the frame  it works up until the screen goes idle, when its idle I try to wake it up but only the backlight works. I can pop the screen out of the frame it will start working again and once it is out I can put the phone in idle and wake it up without a problem.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I have a similar situation
さんによる
コメントを追加
1 件の回答
ベストアンサー
You probably have a mix of a bad quality screen and a bumped housing there and the combination of the two causes that issue. First thing to do would be to try to straighten the housing shape where it’s bumped with a small precision hammer. Or find an original used housing on the market. You could also try reducing a bit the side pressure by gently use very fine sand paper on the screen edges to reduce a bit thickness.
このアンサーは役に立ちましたか?
スコア 4
5 件のコメント:
I second this the housing is probably bumped/bent. Which causes pressure on the screen.
さんによる
The EMI shield pushing against the housing was also causing side pressure. Thanks you very much.
さんによる
It's usually just a bad screen. I've used lots of screens on slightly bent frames.
さんによる
Thank you all, I replaced the screen and it solved the problem.
さんによる
@niairo Great, thanks for feedback.
さんによる
コメントを追加
回答を追加する
Robert Ryan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 69
