メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
623回答 すべてを表示
MacBook Air 2015 - Running slowly, freezing, kernel_task high usage
Hello.
2 days ago my Macbook Air got very slowly and started to freezing when i want to open any of apps. I must to hold power button for 5-10 seconds for turn on my Macbook, when i hold the button for less than 5 seconds, I just hear the sound of starting Macbook and nothing after this. My macbook got a slowly startup to, and when i'm at the desktop without any of apps on, kernel_task have very high usage of CPU, about 270%.
Things i have tried:
  • Fix disk permissions
  • Fix disk with "Disk Utility"
  • Reistall of OS X - got a little bit better
  • Restart of SMC/NVRAM/PRAM
  • Fix Mac with the "clean my mac" - 0 errors
  • Fix Mac with the "Hardware test" - 0 errors
Will change of SDD/battery may help?
I hope you can help me guys.
Sorry for my bad english guys!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It sounds like you hitting a full drive issue, your symptoms line up.
One of the issues this series encounters is running on its limited RAM it needs to use the drive for virtual RAM. So when you have a full drive the needed space the OS needs is not there!
Clean off a good 1/4 of the drive that should stabilize things.
But, you have a hidden problem running your system so tight. Your SSD drive needs to even out the wear (wear leveling) in this connection you tend to over wear the drive so you might be at the ned of life on your SSD. You’ll need to get a utility to check it here’s more Monitoring SSD wear and ageing. I personally use: DriveX
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hello, any other solutions? SDD wasn’t a problem but i see that temp of macbook is high about 70C…
さんによる
Lets run diagnostics to see if an error pop's. Restart your system and press the D key. Did you get an error code?
さんによる
コメントを追加
回答を追加する
kacper tz さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 676
