all apps got erased how do I put them back on the tablet
all apps got eraced so ther is nothing on the tablet to turn on wifi
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi
You may have to hard reset the tablet to re-install the firmware which contains the basic Android apps necessary for the tablet to fully function
Here is a link to the ifixit DigiLand DL700D Troubleshooting guide.
Scroll down to the Reset without complication section first to see if that works. Here’s an image taken from the user manual that shows where the recessed reset button is located. DO NOT get it mixed up with the microphone hole as you may damage the microphone if you insert a paperclip in there ;-)
(click on image to enlarge for better viewing)
If it doesn’t work then try following the instructions in the Passcode is forgotten section to see how to factory reset the tablet.
I believe that the instructions for a factory reset may be wrong and that you have to hold the Power button and the Volume Up and Down buttons (all 3 buttons together) to get into the recovery screen. Once there, release the buttons and follow the guide as before.
Be aware that a factory reset (also known as a hard reset) will erase all your data and downloaded apps. It will restore the tablet to its’ factory default condition (or last system updated condition). It will be like when you first got it.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 123
