メインコンテンツにスキップ
Samsung Galaxy S6 Edge+ はGalaxy S6 Edgeスマートフォンの大型モデルです。
99回答 すべてを表示
I recently got water damage on my Galaxy s6 edge+ now the touchscreen
A month and a half ago my phone got wet so now it won't power back on?! It's been a few days since it got wet, I went to go see if your power back on and it does like it normally does, but the touch screen is unresponsive, I press down on it, but it doesn't do nothing. What can I do to fix that
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @bostongurl69
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
If this process seems too daunting, take your phone to a reputable, professional phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Shanon Lewis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 459
