メインコンテンツにスキップ
食器洗浄機の修理と解体ガイド
707回答 すべてを表示
Power Surge - Now Dead
This morning we had a storm and lost power. There were several surges as the power came back on. After I got power back and was resetting clocks in the kitchen I could smell an electrical burning smell vaguely. It seemed like all the appliances were working, but I did not check the dishwasher. The wife did this afternoon and it is completely dead, no response. I have turn the breaker off for 10 minutes and back on still nothing. My thought is the control board's probably fried. Any thoughts from anybody else? Thanks in advance! Whirlpool Gold Series Model # WDT780SAEM1
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
My power co's line at the pole caught fire and fell onto the service cable to my home and caused some breakers to get fried. i caused some bulbs to explode, serge suppressor to fried, and our dish washer was affected. Is there a fuse in the system that protects the main board from serious damage. The dishwasher is a Whirlpool model DU1055XTVS3
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi @seattlekev ,
A burning electrical smell is not a good sign.
It may be that the electronic control board has been affected by the power surge. The only way to tell is to open up the control panel and inspect the control board for damage.
Here’s a link that may be of some help as it gives the layout of the parts in the Control Panel and also the cost of the control board (part #8).
There are other suppliers if this one doesn’t suit. It was shown just to give you an idea of the cost and location of the part
If you get storms/outages frequently, for the future have you considered having the dishwasher (and other appliances as well) connected to the power outlet via a surge protector (some are inbuilt into powerboards (powerstrips?) etc. At least if a storm or outage occurs it will be sacrificed and not the appliance. The downside is that most surge protectors do not indicate when they have failed (or operated if you like) so after a storm you’re not certain if the protection is still there or not as the power is still available. The better ones do but their cost makes having a few around the place debatable.
As an aside, check the provisions of your Home Contents Insurance policy to see if the home appliances are covered for damage by storms and outages.You may be able to get it repaired/replaced under insurance. Just a thought.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
I sure appreciate it @jayeff! I am having a bit of trouble getting that Model # to Google. I suspect that it is a designated Lowe's #. Is there a reference table anywhere that might cross that # to a more commonplace #, i.e., Whirlpool's factory #? I was hoping to get a little YouTube help along the way.
さんによる
Hi @seattlekev,
I just Googled "WDT780SAEM1 parts" to get a page of results for suppliers.
You could try the same on YouTube, look for "WDT780SAEM1 replacing control board" or similar
さんによる
I wish that I could post a picture so I could show you the blackened exterior of the surge protector that I was smart enough to put on the dishwasher, but smart enough to remember putting on there! I now have a pretty good idea of how to get the entire control panel pieces apart! LOL Thanks for your help! I believe I am good.
さんによる
Hi @seattlekev ,
Here's how to add pictures to your question
iFixitでの質問に画像を追加する方法
Did you check the warranty provisions on the surge protector, if it has any that is?
Where I am they are selling plug-in surge protectors (also powerboards with built in surge protection) that states that they will cover the cost of the appliance repair/replacement if the surge protector fails to protect the appliance. They will not replace the surge protector however.
Not all brands of surge protector have this warranty
This is just an example of the warranty on this brand of surge protected powerboard.
Not pushing them just showing what may be on offer where you are ;-)
さんによる
Well, no problem this time. I am very happy with my Monster Power Single Outlet Surge Protector @ $7.99 and I am currently listening to my dishwasher running in the background! Thanks again man!
さんによる
2件以上のコメントを表示
コメントを追加
Hi @jfab
If there is no power at all on the dishwasher then looking at the dishwasher’s tech sheet, there is a thermal fuse, part #4 Control panel and latch parts diagram in the main power supply path to the control board, that may be worth checking.
Here’s an image from the tech sheet wiring diagram showing the fuse (shown as “non resettable bi- metal”) connected to the active input lead.
(click on image to enlarge for better viewing).
If the fuse is OK check the control board for any obvious component damage
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kevin Michal さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 19
過去 30 日: 103
今までの合計 5,535
