メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Is it possible to fix a broken Pad that connects to the other side?
I was replacing the Touch IC chip on iPhone 6+ but accidentally broke some pads as seen in images below but to fix these pads I would have to wire it to the other side of the board also seen in screenshots of ZXW tool.
Images:
https://www.dropbox.com/s/uw7q0w5z74ui1o...
https://www.dropbox.com/s/336qoy0zutsljo...
https://www.dropbox.com/s/4rte7glffq3fxb...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Sure you can but in order to get the micro-jumper to work properly underneath the IC, you will need some very thin wire. You can source 0.02mm enameled wire from most places that sell micro-soldering supplies. You will also need some UV-curable mask to fix the wire in place so it doesn’t shift around when you heat the IC to install it.
Considering you’re asking the question, I will assume that you are starting out. So my advice would be to practice this on a dead board a few times because if you mess this up, the damage it will cause may become un-repairable.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Do you know any good video tutorial on how to do this when I have the tools? I am practicing on a icloud locked device which I own so that I can practice this skill with my own board as I would feel terrible if I mess on someone else's.
さんによる
コメントを追加
回答を追加する
Cameron Saman さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 69
