メインコンテンツにスキップ
Burnham steam boiler PIN4SNI-ME2, PSI valve replacement
I have the part, but is not sure how to uninstall old and install new. Do I simply unscrew it from the body of the furnace and install the replacement PSI valve. Anything I should be aware of (except, of course that the furnace needs to be off and cold when I do this)?
Many thanks, SE
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Here’s the service manual for your boiler Burnham Independence Boiler
Pressure valves are a very tricky thing. If not installed properly you can cause big issues!
I strongly recommend you get a trained heating technician in to install it for now. If you really want to learn go to a good vocational school to study heating.
Just the other day a home near here blew up! The homeowner tried fixing his boiler and now he’s homeless!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sam engelstad さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 117
