How can I Unlock an iPhone when im not the original owner?
Do the R-Sims work? I bought a phone from someone 2nd hand and they wont respond to any of my messages. How the !&&* can I carrier unlock it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You’ll need to talk with the carrier to see if the phone is still under contract if it is you’ll need to pay off the remainder to get it legally unlocked. If it’s not the carrier should be able to unlock it. Even still it maybe iCloud locked as well.
You may want to stop the payment you gave the seller if you can. Often times this is a ploy to get money for a stolen phone.
このアンサーは役に立ちましたか?
I can’t do any of that stuff because I’m not the original owner.
I guess a good paper weight now ;-{
I am assuming you mean carrier lock and not iCloud lock.
That probably depends on the country you are in. Here in Canada, the original carrier has to unlock it and thankfully, they are no longer allowed to charge for this service. However, if the phone still has an outstanding balance (subsidy), then the carrier will not unlock it until it is fully paid.
How this plays out where you are may be different. Usually your carrier should be able to determine whom it is locked to when you give them your IMEI.
このアンサーは役に立ちましたか?
Nothing you can do is “legal” google searches can provide some small answer but again not legal. if you bought it second hand from say offerup then you can contact them file a police report and they may be able to help you if you have the message proving it.
このアンサーは役に立ちましたか?
I bought it off of OfferUp. The people seemed kinda shady. I tried messaging them about 10 times. No response.
contact offerups support team and let them you know bought something most likely stolen. file a police report too. THATS ALL YOU CAN DO.
also before buying I phone try looking up the IMEI before handing over funds.
I use swappa.com for Blacklist checks
and iphoneox.com for iCloud lock checks.
It’s not blacklisted. I have my Apple ID on it it’s just I can’t use an AT&T SIM card on it
hmmm then that has nothing to do with you being an original owner. maybe its a wrong carrier. did the imii show what network it was on?
過去 24時間: 1
過去 7 日: 11
過去 30 日: 36
今までの合計 3,420
