メインコンテンツにスキップ
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548回答 すべてを表示
What is this iMac component
The computer is an iMac 8,1 2201 Early 2008, HDD has been replaced with a SSD awhile ago.
Recently the GPU die temperature has jumped up for no reason. I usually pay attention to the CPU temperature, not the GPU so not sure exactly how much it has jumped up, but it's about 10 - 20 degrees Celsius, now hovering at about 80 degrees Celsius.
This is normal day to day use, no games or heavy resource use software, and it just went up for no reason. I opened up and cleaned it because it was quite dusty and gained about 5 degrees, but it's still around 80.
What I noticed after I opened it is that all the parts had cooled down, including the GPU, except this component that is next to the SSD and on top of the GPU.
It could be this component that it's the culprit and not the GPU so I was wondering what it is. I have attached a picture in which you can see the SSD and this component.
Maybe you could help me identify it.
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
That’s the power supply unit.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Right, so if my GPU Die suddenly is 15-20 Celsius hotter during normal use, but everything else is fine, what could this mean ?
さんによる
Your systems thermal paste on the CPU & GPU needs refreshing. You'll need to take the logic board out clean off the old paste and apply fresh paste. iMac Intel 21.5インチ EMC 2389 ロジックボードの交換
さんによる
コメントを追加
回答を追加する
Andrei さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 54
