メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
Intermittent power when starting
I actually have a 2001 GMC Sonoma with a 2.2l, the fields wouldn't let me select that. Anyway, I put a new starter in and when I went to reconnect the battery o got some significant sparks…. Well, it cranked right up but after trying a couple times it acted like it didn't want to crank, then it lost all electrical power. Sometimes it cranks smoothly, sometimes it cranks rough, others it doesn't do anything. Please help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Mr. Walters, check your connections on both ends of your battery cables. A poor connections may be causing high resistance. Check your battery with a multimeter as well, you should have roughly 12.6 Volts
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tim Walters さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 103
