メインコンテンツにスキップ
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
20回答 すべてを表示
Prohibited symbol on boot
I purchased a used Late 2012 i7 with 16 GB of RAM & a 2.25 TB Fusion Drive that was running High Sierra,
The computer seem to be working fine, until just before Christmas it booted once and I got the prohibited symbol. I had not yet moved things over to it so I did not loose much. I rebooted into recovery and reinstalled the OS.
It worked fine for a few days then it happened again. I ran disk utility in recovery mode then disk first aide without much progress. I reinstalled the OS through Disk Utility and 6 hours later I was running again but hesitant to use this machine as a main hub for photos and my iTunes library now that I have had 2 crashes in a few days.
I have searched the web with little to show for it.
I ran Ertchecker and came up with the some results however my post has been deleted 3 times already and i think that is why.
EtreCheck Report
Is the drive failing or is there something else? RAM? The SATA Cable to the drive?
I also saw on this: Upgrading from HDD to SDD, but get prohibitory symbol when booting up?. Is this possible?
I thought It might be my 2TB mechanical drive was starting to fail but searches on the internet came up with nothing.
I now see looking back through one of my RAM chips was not seated correctly or is starting to fail. I know when I got the computer when I ran system profile that the I had 16 GB of RAM. If one ram chip was not seated would it boot at all?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
Do you have an external Time Machine backup. What two drives constitute your set up?
さんによる
I transferred your other info over from the closed question. The system won't allow URL postings with new members which is why it kept getting deleted.
さんによる
The MacBook link doesn't apply here.
さんによる
There is no time machine backup of this computer yet. I was waiting to move my iTunes Library and Aperture Library to this computer from an external drive and then use the drive as a time machine back up. There is a 250 GB SSD and 2 TB HDD set up as a Fusion Drive. That is the drive you can see referenced in the document attached above.
Note: thanks Dan for helping move stuff around.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I’m suspecting your system is accessing the original owners iCloud account which is set to delete the drive. You’ll need to contact the original owner or get your money back from the seller.
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
I can't do a fresh install to get around the original owners iCloud?
さんによる
Sorry your system is still communicating to the iCloud server and you can't kill it as its part of the SMC/EFI function.
さんによる
I Highly doubt Im going to get my money back from an eBay listing, what can the original owner do to help me get out of this situation? I googled your SMC/EFI function and there is a way to reset the SMC according to Apple, https://discussions.apple.com/thread/269.... If my google search for EFI has found what I think what you are referring to https://support.apple.com/kb/PH2701?loca... he/she still has access to the computer via iCloud and he is continually erasing it on his iCloud? can he remove it from his account?
さんによる
Dan, I believe I can reinstall my hard drives, fan, RAM, Antenna plate, and cover and boot, because you are confident that its a software/firmware issue?
さんによる
Not software - Firmware
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Matt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 296
