メインコンテンツにスキップ
長く待ちわびた人気モデルMac miniの最新モデルです。プロセッサはオプションで3.6 GHz quad-core Intel Core i3、3.0 GHz 6-core Intel Core i5もしくは3.2GHz 6-core Intel Core i7プロセッサから選べます。
20回答 すべてを表示
Broke the socket off logic board that fan attaches to. Fixable?
Was upgrading Mac Mini 2018 RAM and accidentally pulled the fan connector “socket” off the logic board! Looks like it may been attached with some kind of adhesive at Apple.
Is this fixable? I hope I didn’t just turn my brand new Mini into a paperweight!
Any help appreciated!!
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Can you post a few pics showing the damage iFixitでの質問に画像を追加する方法
さんによる
Sure. Photo has been attached.
さんによる
@cw2 - You're lucky too! The pads are still intact on the logic board. You'll need to find someone with the needed tools and skills to solder it back on.
さんによる
コメントを追加
4件の回答
ベストアンサー
FIXED!
Took my Mac Mini to the Apple Store, and they said the only fix they could do was to replace the entire Logic Board. They said since I “just bought the computer” they would replace it for FREE! Even though, I was the one who broke it doing a memory upgrade!!
GREAT customer support from Apple on this one!!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Cheryl to be clear, are you saying Apple replaced your computer? I have a customer that did the same thing to his brand new Mac. It’s never even been used. i’ll be taking it in today and hope they will honor the same offer they gave you.
Thank you.
 Chris Leeds Independent Apple Specialist Well Connected Life
さんによる
They did not replace the whole physical computer. They opened my Mac Mini and replaced the logic board.
さんによる
コメントを追加
最も参考になった回答
It is fixable only through Micro Soldering
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Thanks. Micro Soldering is above my level of expertise, so I guess I will have to see if an Apple tech can repair it, or if I need to just order a new one with the 32 Gb of RAM and end up paying $3600 (including the original one I broke) for a new Mac Mini! Lesson learned: Never try these upgrades at Midnight. And if you feel a little uneasy about your skills for an upgrade, trust your instincts.
I am happy to hear others are having better luck than I did, however.
さんによる
You''ll need to find an independent Apple person, Apple or its authorized service partners won't touch it either ;-{
さんによる
I had the same problem. I was able to solder it back on with a regular soldering iron and a soldering iron stand with magnifying glass. It took me about an hour with multi tries to do it though. I'm writing this on the upgraded Mac Mini with 32Gb of RAM.
さんによる
コメントを追加
Here's someone else who facing the same issue: The connect point of WIFI antenna was broken during tear down. Depending on your damage you might be as lucky.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Cheryl,
Thank you for your information. Presently, the best answer here as voted by others here is “micro soldering.” Based on my personal first-hand experience I must disagree.
I took my client’s Mac Mini with its broken-off fan connector back to Apple. I explainED the situation that the customer had tried to upgrade the RAM and left it at that. Seeing as it was a pretty new purchase, Apple agreed to send it to Depot for repair.
It came back fixed with its original warranty, completely free of charge. How’s that for an answer?
Thank you.
Chris Leeds
Well Connected Life
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cheryl さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 2,596
