メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Boot loop after swollen battery replacement, 4013 error
Phone: iPhone 6
Cable: genuine Apple cable
Charge brick: genuine Apple
Swollen Battery: iFixit battery, less than a year old
Replacement Battery: iFixit battery
I realize this issue is documented and answered in places. but felt my situation does not perfectly match those, and needed more answers.
What happened: I started noticing the battery swelling and pushing the screen up about 4 weeks ago, mid December 2018. The phone was crashing when it wanted. What I found to stabilize it was having it plugged into an Anker power block at all times. Needing my phone for, well, everything, I ordered the replacement battery, and kept it plugged into the Anker for stability. The phone was actually working and stable with the Anker life support system it was on.
I received the replacement battery, performed the surgery according to instructions. I have moderate expertise with small electronics, been fixing them off and on for years.
When I went to power the phone up, it was stuck in an endless boot loop of the Apple logo. I need to get into the phone pretty badly for data on it, data that was fresh from the last backup - holiday pictures, notes, etc.
Went back to the swollen battery, with Anker, same thing.
So, I got it to go to recovery mode, hoping to do the update option, so that the data would be preserved. When I plug it into iTunes, it gets ready to engage the phone, but the phone just enters the boot loop over and over and won’t allow the update. or anything else.
Any insights and help are much appreciated.
Eric
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Such error actually happen while on Nand data is crashed due to some region.So need to reprogram the NAND with valid info by Nand programmer.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Thanks Akash. will you please break this down for a newbie?
さんによる
This process is as complex to do without special equipment and knowledge.If not contact the technician may help you to fix.Search on ifixit by this topic brother.
さんによる
Thank you Akash!
さんによる
In short data is going to be lost to fix the phone. I see bad batteries a lot corrupt firmware and user data on the phone.
If you tried doing an update via 3uTools usually it shows error -26/-27 for corrupt file system in that case you'll need to restore the phone.
さんによる
コメントを追加
Did you solve this ? I’m having the exact same problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I was told it wasn’t possible by one outfit. Then another told me they would try, assess it. I didn’t follow through at the time, and then the virus hit. Still have phone and might send it out. Not a priority right now.
good luck.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
thanks for the quick answer. I'll try to fix mine, but seems it won't be easy. In the meantime if I find a solution, I'll reach out to you.
さんによる
コメントを追加
回答を追加する
Eric Carlsen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 436
