メインコンテンツにスキップ
任天堂スイッチは、ドッキングステーションを介してテレビで遊んだり、外出先で遊んだりできる携帯型ゲーム機です。2017年3月3日に発売されました。
Nintendo switch is charging insanely slow
I am having a problem with my switch and I was wondering if there's a chance you guys could be of assistance at all.
So I have a nintendo switch that is giving me some issues. It's never been used on any 3rd party dock or chargers, only the official supplied chargers. I hadn't played it for about a day or so, and when I came back and tried to turn it on it was dead. When I plugged it in it would show the battery symbol, but never charge up enough to get it to boot. I googled around for about an hour and tried everything possible with no success.
I then booted the switch into RCM mode and was able to boot to Hekate. Through hekate I can see that the battery capacity is 100% of the original capacity, but the current capacity is somewhere around 3%. From there I tried a battery fix tool that is built into Hekate, that did not solve the problem. After that, I rebooted the console through Hekate. This time, to my surprise, it actually booted all the way through. My profile loaded up and everything came back. The problem now is that the switch still is not charging. The device will stay on, but it is currently stuck at 2%. If I turn the device off and leave it charging it will now charge incredibly slow, and eventually deplete again when turned on. The good news is that the device will now turn on if left on the charger for an hour or two.
I have a few years of experience repairing electronics and soldering devices, so I figured I would open it up and take a look. I did a lot of googling and gathered all the info I could, and then went to work. The charge port seems to be working fine, currently the switch is pulling .47A at 4.97V. I am checking this using a little dongle and a 3rd party cable. As far as I can find, this means that the device is charging correctly. When I check pin 5 on M92T36 I get 3.29V. According to a few people on the internet (which may or may not be accurate), this means that M92T36 is not the problem. I believe this is one of the most common problems with the switch right now, so I was surprised to see that it is (again, I could be wrong) working fine. From here, I tested BQ24193. On both VBUS pins (1 and 24) I am getting 4.8V, and as far as I can tell this means that power is getting to the chip. All of these readings are while the device is plugged in. After this, I turned off the device while it was plugged in and left it for around 30 minutes. I then booted back into Hekate, it told me that the battery was at 10%. So the console is getting power, but it's charging very slowly.
I just tested the battery to make sure that was working as well. While plugged into the system (the battery, the charge cord is unplugged) I'm getting 3.5V from both of the positive power lines. With the battery unplugged I'm still getting 3.5V from each positive power line. The battery says it has a 3.7V output, so this is close enough. I believe the battery is fine based on these measurements.
With all of that said, is there any chance you guys could provide any assistance to me? If I could be pointed in the right direction I could keep trying to figure it out, but at the moment I'm stuck. I can't seem to find any more info as far as what I need to check to see if everything is receiving the correct amount of power. From what I can find everything is testing fine, so there must be something that I need to check that I can't find any info on. If you guys could provide me with any info that would be amazing.
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
5 件のコメント
so, i used a usb-c hp probook charger (65w) to try and charge a switch, but it wouldn't turn on! Then i smelled it! there was this HORRIBLE burning plastic smell, and after that it wont charge even with a normal usb-c, in fact my friend's cord apparently is now totally shot! however, if i were to charge it slower, with a cord that's power is severely reduced, could it charge, albeit VERY slowly?
さんによる
i have the same probelem but for no reason instead. i use an onn. usb-c charger, have three of them. none of them work right so i just decided to leave it
さんによる
Having same problem. I tested my soldering skills by changing the usb port. Port works but still same problem. Charges super slow. So most likely the chip now. Gonna try that now
さんによる
To charge faster, use the charger that came with the console.
さんによる
This was happening to me and when I came home from work I saw that my switch wasn't done charging and I was a little bit mad Abt it
さんによる
コメントを追加
5件の回答
ベストアンサー
How long did you leave it charging? Switches will slow charge (around .40-.47 or so) for a long time sometimes. I've seen them slow charge for hours. That's what I would try first...just leave it charging overnight.
このアンサーは役に立ちましたか?
スコア 6
5 件のコメント:
Had one last weekend and that fixed it, now the next charge was "normal" under couple hours, while the first one took about 8 hours to fully charge.
さんによる
Ya, I've had some take an extremely long time.
さんによる
My switch has been charging for 24 hours and only went up by 30%, not to mention it was at 5% when I started.
さんによる
Mine takes at least overnight and sometimes two days to charge. It charges too slowly to play it while it’s charging.
I’ve pretty much stopped using it for these reasons.
さんによる
My switch is taking a bow on an hour and it only charges up to 10% basically or sometimes it charges only 10% when it has been charged for 3 hours
さんによる
コメントを追加
I have had luck in the past with replacing the battery in this exact situation, although sometimes even a battery doesn’t seem to work. These power issues are super common on the Switch and it sounds like you’ve ruled out the other most likely causes (the USB-C port and the charging ICs). If a new battery doesn’t work try asking @tronicsfix if he has come across anything new. Good luck!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My son’s switch had a black screen after sitting idle for a month while he was away during summer break. It would not take a charge, or so it seemed, but the LCD light turned on and off when we docked the console.
I checked all the obvious solutions and read solutions to the above posted question. Then followed the link to Nintendo’s website hoping to read about a recall all to no avail.
Fortunately, I read an article about the “console not charging, a black screen and won’t wake up from sleep mode”. D’uh
It froze in sleep mode, the battery died and a proper reboot solved the problem. Which is holding down the power button for 12 seconds along with a couple other omfg that’s so simple solutions! And then I’m the ifixit goddess until I explained the problem and hard restart solution
See for your self…
https://en-americas-support.nintendo.com...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It took an hour to charge 😒
さんによる
コメントを追加
it is normal it is because I have a brand new switch I got it like 1 day ago and it still charges slow because the battery is very big and things like those batteries need more energy then normal batteries example big batteries takes up more energy then normal sized batteries while on the other hand normal sized batteries takes less of the energy then a big sized batteries it takes less time to charge than big batteries.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
shut the &&^& up
さんによる
コメントを追加
Well my switch is on charge and it took over an hour to charge the screen was black with a battery in the corner but it would not go up
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andrew Guerrero さん、ありがとうございました!
統計データ:
過去 24時間: 32
過去 7 日: 254
過去 30 日: 1,204
今までの合計 119,692
