メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
276回答 すべてを表示
I was using my computer, and it suddenly shuts down, won’t turn on
The computer shuts down and tried to turn it on… won’t turn on. Connect to the power outlet. It does not make any chime noise when connected to the outlet power.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Try a spontaneous reboot. To do this, disconnect the battery and mag-safe. Press and hold the power on button for ten seconds. Reconnect the battery and mag-safe. It should spontaneously reboot.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
@mayer - USB-C, no MagSafe here.
さんによる
コメントを追加
To start with make sure you are using the charger and cable that came with your system.
The USB-C cable Apple supplied is designed for power unlike most other USB-C cables which are designed to be for data. The wire gage within the cable is thicker for the power feed needed for your system unlike the data cable which is using the thinner wires for data and low current device support.
You’ll need to work through a process here to isolate out what has failed. Often times the charger or the cable has failed or is the wrong part. Unlike older MacBook Pro’s there is no charging light so you just don’t know whats happening. I would recommend getting a USB-C power meter Satechi USB-C Power Meter Tester it will allow you to see whats happening.
You may want to visit an Apple Store to have them check your system. Hopefully you still have warranty coverage or have AppleCare+ extended coverage.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
appology dan posted on Mac
さんによる
コメントを追加
回答を追加する
Abragam さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 87
