メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
20回答 すべてを表示
No cellular reception - first course of action?
I have been handed a phone to fix which has no cellular reception, but connects to WiFi. What would you recommend would be my first course of action with this? What antenna should I replace? It has already been reset, so it isn’t a software issue.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Try dialling *#06#, that should give in return the IMEI number..if you get nothing it’s a typical baseband fault that needs a microsoldering repair. If IMEI is there you may try to get a replacement lightning connector which has the main cellular antenna embedded, if it’s an antenna issue on your present lightning assembly with the new one you should have some at least some weak signal even if the dock is not properly mounted to the housing.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thanks! I'll try that, and then comment back the result.
さんによる
Dialling *#06# doesn't return anything, so it is a baseband fault? How hard is this to fix for the microsolderer?
さんによる
@albert8181 It sounds like a baseband issue. I personally fixed a few but had some that didn't have anything to do with the usual edge faulty pads, in which case it may be very time consuming given the great number of BB related components. An experienced microsolderer shouldn't have major problems fixing the BB itself, if it's a secondary issue much depends on diagnostic skills and time available.
さんによる
コメントを追加
回答を追加する
Albert Einstein さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 60
