メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Antenna went bad slowly 3 times
My antenna has slowly gone out on my iPhone 6. It started by going to roam in places where I used to get service, then it just went to searching. Resetting network settings worked a couple times, but only for an hour or so. Replaced SIM, nothing. Had the internal antenna replaced and it worked for a day or two and then went to roam and then searching. I replaced the internal antenna and WiFi antenna and the same thing again, roam and then searching. What could be the cause of my issues? Rear case “actual” antenna issues?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Would a typical repair shop be able to perform this if it needs it. Slide my SIM card back in and it worked for a second, then checked the “flatness” of the phone and gave it a good press seems to be work long for the time being.
さんによる
@wmyoungiv If the repair shop does microsoldering it should be able to fix it in most cases by removing the chip and reworking it, disposing of the oxide and/or most fragile solder joints. If the board inside lays flat contacts might work longer but it's usually a matter of time that signals/power will stop flowing completely if not taken care of.
さんによる
コメントを追加
1 件の回答
ベストアンサー
It’s probably not an antenna related problem, iPhone 6 are known to develop this issue especially if they’ve been dropped or got bent. When you get the no service/searching try dialling *#06#, that should give in return the IMEI number..if you get nothing it’s a typical baseband fault that needs a microsoldering repair.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Walter さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 61
