メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Why does my camera still freeze after change
Hi!
I'm quite new to phone reparations but still wanted to give this a try.
So my problem is that the front camera didn't show any image on the phone before I replaced it with a new one. However it still doesn't show any image.
The replacement was front camera, sensor etc.
So the question remains to what the problem is.
Once again I'm quite new and would love tips and what to try and check what's wrong. iPhone 6 is the phone.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
First, I would check if your other top components work, such as the earpiece speaker. If so, the flex cable is probably okay, but there could be some pins damaged either on the flex cable itself or the logic board connector. I would disconnect the flex cable from the board, maybe spray some canned air on it, then reseat it. Either you need a flex cable replacement (whole top components), or the logic board has a short / broken pin.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I Will try and check that when I got time this weekend. Thanks for the replay for now.
さんによる
コメントを追加
回答を追加する
Jack Plumeyer さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 19
