メインコンテンツにスキップ
統合されたディスプレイを持たない一般的な据え付けのコンピューターです。
2133回答 すべてを表示
CPU error LED is on, fans are working and hdd is spinning but no boot.
My specs are: zotac gtx 970, intel i5 6500, two sticks of 4gb crucial 2133 mhz ddr4 ram, 500gb samsung 850 evo ssd, 2tb seagate barracuda hdd, msi h170 pc mate, and corsair h60 cooler, with a evga 500b psu.
I was using my pc in the morning and it was working fine with no abnormalities. When I tried to turn it on later that day, I heard the fans start spinning but no beeps from my mobo and no boot. Currently I am running a test bench style with my mobo sitting on my cpu box to eliminate the possibility of a short resulting from the case. Unfortunately, the error LED for the cpu is on when I turn on my computer and it is still not booting. What should I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
have you tried booting the pc with the video card disconnected and monitor plugged into the mobo? also try check to see if any cables loose or settings on monitor are correct. if this is a newly built system and the error is it spins and turns off, check to see the cpu cooler is on properly, if it overheats the cpu too quickly, the pc will shut itself off.
さんによる
The system is more than two years old and has been working without a hitch until now. When I try to turn it on the fans spin until I power the system down so there is no crashing taking place. I just tried to boot without the video card and the monitor plugged into the mobo but still no success. I have also tried moving around the ram and attempting to boot with only one of the sticks but that has not worked either.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi @eggo5 ,
The CPU led indicates either the cpu is not detected or has failed.
Did you try to reset the BIOS just in case it is a corrupted BIOS problem?
This is from the motherboard user manual:
Resetting BIOS to default values:
1. Power off the computer and unplug the power cord
2. Use a jumper cap to short JBAT1 for about 5-10 seconds.
3. Remove the jumper cap from JBAT1.
4. Plug the power cord and power on the computer.
If that doesn’t work perhaps you should check if the PSU is supplying the correct voltages to the motherboard.
To do this disconnect the AC power from the computer and then disconnect all the power cables from the PSU to the motherboard and associated hardware i.e. GPU card, HDD etc.
Next on the 24 pin power connector from the PSU short out pins 16 -17 using a bent paper clip (or similar- see image below, usually pin 16 is a green wire but it can vary).
Reconnect and switch on the AC power to the computer. The PSU should turn on (PSU fan should turn on) and you can now test the various voltages supplied by the PSU to the 24 pin connector (and the 8 pin connector) using a DMM’s voltmeter function.
The 12V supplies should be OK as you say that the fans are working, but check them all anyway..
Of more interest is the +3.3V and the +5V
(click on image to enlarge for better viewing)
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Tengo una Z370 gaming 3 aorus y trabajando se reinicio y se quedó con el indicador led de cpu encendido, cambie de cpu y mantiene el error, ya le quite la pila y reset la bios pero nada
さんによる
コメントを追加
回答を追加する
Tommy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 2,677
