メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
419回答 すべてを表示
What is the maximum RAM that the 2011 21" iMac can take?
On intel.com the processor in my machine is the i5-2400S. It is listed as being able to support 32 GB of RAM.
Can the board in the iMac support that much?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
imac mid 2011 21" too: 32gb max 1333 1,5v
さんによる
コメントを追加
4件の回答
選択されたソリューション
Everymac has the maximum listed as 16 GB: http://www.everymac.com/systems/apple/im...
By default, 4 GB of RAM is installed as two 2 GB SO-DIMM modules. Two slots free. This model supports four 4 GB modules -- one in each slot for a maximum of 16 GB of memory.
このアンサーは役に立ちましたか?
スコア 7
コメント:
I installed 32 gb ram in my mid 2011 iMac 2.7 GHz without issues it addresses 32 gb/recognizes it
さんによる
Findings change over time. Everymac now has it listed at 32. We also now know what Pluto looks like.
さんによる
While its cool to push the limits, do you have an app they can even leverage this much RAM or can you even load up multiple apps that collectively would leverage this much! We work on very large CAD & DB files and we are just bumping up to 12GB. While we don't run many apps concurrently I just don't see the need yet to push past 16GB.
さんによる
Dan it's called wazoo issues: https://www.youtube.com/watch?v=oftjwYml...
さんによる
@Mayer - I like it! ;-}
さんによる
3件以上のコメントを表示
コメントを追加
Hi Mayer, the Everymac website says
"Officially, this model supports four 4 GB modules -- one in each slot for a maximum of 16 GB of memory. However, third-parties have discovered that it actually will support 32 GB of memory using four 8 GB modules."
what do you think? is the 32 GB correct info?
Update
Daniel Shugert, where did you buy the 2x8gb chips? do they have an specification for Mac? i thing something related to Mhz speed i guess. Cheers.
このアンサーは役に立ちましたか?
スコア 1
コメント:
I have a 2011 21" iMac i5. I installed 4 8GB RAM from Crucial. It struggled a little bit and finally worked flawlessly. I am using these RAMs to run multiple VMs with Parallels Desktop.
さんによる
コメントを追加
i have 20gb installed. the stock 2x2gb and an additional 2x8gb chips
このアンサーは役に立ちましたか?
スコア 1
コメント:
i got them here:
http://www.crucial.com/store/listparts.a...
they're now almost half what i paid for them. may just have to grab another couple of sets and bump the iMac up to 32 and the i5 mac mini we have up to 16.
さんによる
I just got this now, how is your mac running? Ever since?
さんによる
コメントを追加
I have seen this model work with 4 x 8GB = 32 GB
このアンサーは役に立ちましたか?
スコア 1
コメント:
But are there any downsides. I am told there may be a throttling of the memory making it slower. Is this correct?
さんによる
Unless you are working with very large data sets, images or video animation. One does not need this much RAM. We do some very large CAD drawings and 16 GB is more than enough.
さんによる
コメントを追加
回答を追加する
Matthew Brusven さん、ありがとうございました!
統計データを表示:
過去 24時間: 6
過去 7 日: 28
過去 30 日: 102
今までの合計 29,886
