メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1199回答 すべてを表示
Replace Broken Screen - Few Questions
Hello,
I want to figure out exactly what I need and need to do to replace a broken screen for an iPhone X. When I check the iFixIt page for iPhone, it shows “screen and digitizer”. So there are two parts. First off, what exactly is the digitizer? From what I understand, that is what gives the iPhone touch capability - is that correct? How do I know if I need to replace just the screen, digitizer, or both? Lastly, is there a big (noticeable) difference if I replace the screen with LCD as opposed to AMOLED?
Thank You!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
You CANNOT peel the screen from the front glass or digitizer, this requires professional equipment and still has very high failure rate and bad overall quality no matter how careful you try to be.
From now on ALWAYS treat the front glass, digitizer (if there is a discrete piece of it) and the display as one unit.
I don’t think you can replace the screen with different type. I’ve heard some brands of aftermarket iPhone display panels but I don’t think there is an IPhone X LCD variant.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
for having 43K rep you dont seem to be very experienced in iphone screen repair......you CAN "peel" the glass from the lcd. it does require professional equipment but an experienced refurbisher should have no issue with "high failure rate" or "bad quality" in fact thats how you get the best quality replacement screens.
and there are 3 different quality screens on the market for iphone 10 currently. am lcd, am oled, and oem refurbished.
さんによる
Actually there are 4 if you include aftermarket TFT iPhone X.
さんによる
We are talking iPhone X here. You can peel LCD easier, but try your luck on flexible OLED panels, very few refurbishers can easily and reliably refurbish iPhone X screens. It’s super easy to damage the screen during disassembly and vacuum bonding process. Most repair shops only offer intact screen assemblies taken straight from other phones in China, and we are talking about the China where everything is possible here.
さんによる
コメントを追加
there are 3 different replacement screens qualities on the market. aftermarket lcd aftermarket oled and oem refurbished. in my opinion the am lcd is trash and dont waste your money. the am oled is the way to go for price vs quality. its hard to distinguish between am oled and oem oled. just do youself a favor and dont use the lcd.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Firstly when you buy a screen it will come with both the screen and digitizer. Which is fine and you can easily assemble this into the phone, if you replace with a LCD instead of OLED then you will notice a change as the LCD is not as sharp as OLED and the LCD also uses a backlight which OLED does not
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if its just the glass that's cracked and everything works as it should then get a replutable company who do a glass only repair/replacement so you keep the original quality. if the OLED is broken then find a good quality replacement (one whole unit).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ezra Shiram さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 142
