メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
Phone keeps restarting after new screen
I happened to change screen of iPhone 5s/SE and after replacing the screen It keeps stuck on Apple logo and sometime it does on home screen and after few minutes it restarts the phone. and keep going on again and again.
Even though I change original cracked screen back , thinking, that new screen was faulty, did not make any difference.
Also, I change new battery , thinking, battery got broken or diffused. But nothing is working.... I contacted couple of technicians and they said that it happened with them with iPhone 7.
Can you advise me that how I can fix iPhone 5s /SE ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Sounds like random rebooting caused by accidental pry damage right above the battery connector.
If you look closely above the battery connector you may see some damaged or missing components there are 4 right above that connector.
One of them is responsible for reading the information from the battery.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
it happened to me also. do you have any solution for this?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I believe previously answered by Ben , seems correct. Some device condition need to be handle with extra soft hands like 5 series. While we disconnect battery it made some little tempered on the board , unnoticeably.
I have started to take extra when using prying tools now its not happening at all.
さんによる
will do next time. thanks!
さんによる
コメントを追加
回答を追加する
iRepairMan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 663
