メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
1364回答 すべてを表示
iPhone screen going rainbow coloured?
Just carried out a screen repair on an iPhone 7 Plus.
Sometimes when waking it up, the screen will be of a largely rainbow tint on the left side. Touching the screen or moving it around solves the issue.
Anyone have any idea what this could be?
I have attached a picture of the phone prior to the repair and a video of the rainbow.
Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Is there any spongy feeling when you lightly press down on the screen on the bottom right corner? If not return the part and get a replacement screen. Could be a bad LCD or you screens IC is being pinched between the bottom of the logic board and loud speaker.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
@toreskey Nope, no spongy feeling. The only reason I didn’t know it if was to do with a faulty LCD is because it’s only sometimes. Usually when I see faulty ones, they’d be a line down it, or an area of the digitiser doesn’t work. Didn’t know if something that only occurred on some occasions was to do with a faulty part.
さんによる
@toreskey Because literally, I’ve just had it again. Scrolling up and down on the screen fixes it. Also, it flashed like a faulty digitiser does when it moves itself up and down. But after doing that, it goes back to normal
さんによる
I would see if you can get a replacement screen then. If you did the process properly, It's most likely a faulty screen.
さんによる
@toreskey Okay, I’ve got plenty. Thanks for your help.
さんによる
コメントを追加
回答を追加する
Sam Mileberg さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 14
今までの合計 2,061
