メインコンテンツにスキップ
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
Are Xbox One and Xbox One S controller faceplates interchangable
Is it possible to put an Xbox One controller faceplate on an Xbox One S controller (given that I have a complete original controller)
I want to have a Bluetooth model with a look of the Limited Edition Halo 5 controller…
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Depends on how much you care about the warranty and if both controllers use the same faceplate and cosmetic parts. If it will work and you care about keeping the warranty, use a skin. If you don’t care (or it’s the 90 day warranty that isn’t worth preserving if you can do the work yourself), then it can be done.
You will need to damage the identifying label (which will reduce the resale of the controller) and make it harder to sell later on to normal buyers (technically capable buyers probably won’t care) so you need to decide if the resale loss and voided warranty are worth having that faceplate.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
!Yes it would work and you only need to unbolt some screws and change the face plate Follow the guide!
Xbox One Wireless Controller Model 1708 Cover Plate Replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vincent さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 22
今までの合計 1,548
