メインコンテンツにスキップ
2009年6月発売、2.66, 2.8, もしくは3.06 GHz Core 2 Duo Processor
300回答 すべてを表示
What is correct name or P/N of camera bracket and where can I buy one.
Macbook Pro, mid-2009, 15” - screen repair
In this ifixit repair image the person is shown using a blue pry-device to remove a part that is referred to as a “camera bracket”.
I lost this piece when I was working on the screen of my mid-2009, Macbook Pro 15” and I need one of them. I have looked on ebay but cannot find anything called a “camera bracket” that looks like this part.
Does anyone know what the correct name of this piece is, or its part number, or where I can buy one?
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Sorry the part is not available as a spare. You’ll need to recover it from your old cover glass as the one you bought to replace it often don’t have them.
If you are really skilled you can make one out of black card stock ;-} I had to do that for a customer who lost his cover glass altogether.
Otherwise its a new cover glass which has the clip [リンクされた製品が存在しない、もしくは無効: IF161-050] Just double check with IFIXIT that it has it.
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
Thanks Dan, but I don't have the part any longer.
I had removed it from my broken cover glass and clipped it back into the frame of the top cover around the camera, but I didn't get a replacement cover glass for a week or so, and in the meantime the part fell out and I lost it.
In my younger days I could probably have made one out of black card stock as you suggest but my eyesight has degraded since then and now I would not be able to see clearly enough to do it.
Do you know what function the part serves? Is it just to hold the camera in place?
If so perhaps I could use a black rubber O-Ring of the right size.
This hardens my resolve against Macs. I only get involved with them to help friends. For myself I always buy secondhand, business-grade, Lenovo Thinkpads which are the epitome of repairable, each one having its own repair manual and parts list.
Thank you for your help
Mike
さんによる
@jrmwalsh - All laptops use custom parts so you'll encounter the same type of issues with a Dell or HP. So I wouldn't get angry at Apple for that.
Sorry to hear you lost it. Send IFIXIT an email to see if they have a spare.
The part aligns the camera to correct location within the cover glass as the camera can shift out of the window.
さんによる
@jrmwalsh - Sorry that won't work. You need to mount it to the glass without fogging the glass. I think you'll need to just find the part or make it using card stock it's not that hard.
さんによる
Thanks Dan,
Mike
さんによる
Thanks Dan
Re: "All laptops use custom parts so you'll encounter the same type of issues with a Dell or HP. So I wouldn't get angry at Apple for that."
Thanks and "Yes" - I have been fixing laptops for 20 years and I know all laptop manufacturers use custom parts.
My dissatisfaction with Apple is not just based on this event- this event is just one more insult in a very long list of insults from Apple.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Michael Walsh さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 9
今までの合計 67
