メインコンテンツにスキップ
Released September 2016. Identified by Model No. SM-G610
166回答 すべてを表示
Samsung Galaxy j7 prime
I dropped my phone in water, and I thought that I was in the clear. After I put it in rice, and took a hair dryer to it. Then in the morning my phone was melted to the charger, with some needle nose pliers I was able to get the charger off. To my surprise it still charged. Then I started having to get it in the right position to charge, and then not at all. I thought I'd by a charging pad, but I can't find one for my phone without having to use the charging port. I can't afford to buy a new one for the next couple of months, so am I just going to have to live without a phone? Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Yikes. Water damage is an issue. Contrary to popular belief, rice does NOT help.
You will need to completely disassemble the phone and clean it with isopropyl alcohol as detailed here: Electronics Water Damage
and for your own safety, you should replace the battery: https://www.amazon.com/Original-Samsung-... as batteries and water don’t mix.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Johnwstewart さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 199
