メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Inspiron 15-5565は、Dell製の15インチノートパソコンです。
Laptop doesn't power on
Opened my laptop to clean out the fan. After I reassembled it, it worked fine, but I realized it was not charging. I took it apart again and realized that i forgot to re connect the adapter port to the mother board. I reconnected it and reassembled and now the laptop will not power on. Nothing happens when I press the power button.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Hi Andrew, when you connect the power adapter to your computer, do you see an indicator that there is power?
try reseating the LVDS cable to the power button to the main board.
さんによる
GPU and CPU are integrated on the board. Is it possible I shorted a power rail the second time I took it apart?
さんによる
コメントを追加
1 件の回答
You can take it apart again and see if you find anything along the way. Check the seating of the video card, CPU [ and the cam on the CPU ] and memory. It may work when you put it together, if so you have had a win. There is also a chance you have done nothing wrong, it may have been ready to fail next power on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Andrew Young さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 370
