メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
iSight camera not detected after maintenance
After replacing the battery and speakers in my Mid 2012 Retina MacBook Pro according to this guide, I reassembled the computer and noticed that everything worked perfectly except for the iSight camera.
Symptoms:
  • No green LED when attempting to use the camera
  • "No video capture devices were found.” in System Information > Hardware > Camera
  • No camera visible in System > Hardware > USB
  • “No camera available” in FaceTime, Photo Booth, and Skype
  • Apple hardware diagnostics shows no camera detected
Solutions attempted:
  • Reset PRAM/NVRAM
  • Reset PMC
  • Tested with a brand new admin user
  • Attempted to boot into Safe Mode, but the boot loader seemed to freeze at the very end
  • Booted into network image at the Apple store and no camera was detected
  • Kill VDCAssistant and Apple CameraAssistant (They were not found; I don’t believe these processes exist on Mojave)
  • Unseat and reseat the camera cable (twice)
  • Inspect the camera cable (no visible damage)
Before replacing the battery and speakers, I occasionally had an issue where the camera would not be detected but a quick reboot always solved the problem. When disconnecting the camera cable during the battery replacement, this cable was the most difficult to remove. I had to apply a good bit of force, but the port is still solid on the logic board and there’s no visible damage to the cable. I always pried (alternating) on the protruding sides of the connector until it wiggled out.
The only 2 theories I have left is that the cable may be very sensitive or I may have blown a ferrite bead although I’m 90% sure I never disconnected or reconnected the cable while the battery was connected.
How sensitive is this cable? How can I determine if a ferrite bead was blown? Does anyone have any other ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Ferrite beads can be tested for continuity with any multimeter, if blown you lose continuity. However, by experience, in some cases, continuity is not sufficient to guarantee a correct performance unfortunately.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Any idea where I can find schematics that detail which components I should check?
さんによる
@brenan First you'll have to find on the board the reference number, it reads like 820-xxxx. With that at hand you'll be able to google out of the net what you're looking for.
さんによる
Apple Part #:
661-6482
Manufacturer Part #:
820-3332A
さんによる
コメントを追加
最も参考になった回答
Disconnect the camera as show in step #6 of this guide:
MacBook Pro 15インチ Retina Display Mid 2012 のロジックボードの交換
Blow it out with canned air and carefully reseat it.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
I gave this a shot. Connection looks pretty clear. No success. https://www.dropbox.com/s/2cgb7ut662j3kr...
さんによる
コメントを追加
I have this same exact problem. No solutions found.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brenan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 2,822
