メインコンテンツにスキップ
対象のモデルはA1419 / EMC 2806 / Late 2014 または Mid 2015。 3.3 または 3.5GHz Core i5 または 4.0GHz Core i7 (機種ID iMac15,1)、EMC 2834 late 2015 / 3.3 または 3.5 GHz Core i5 または 4.0 GHz Core i7 (機種ID iMac17,1)のRetina 5Kディスプレイを搭載したすべて。
573回答 すべてを表示
Half retina screen flickering when moving the mouse, blacks out
As the description says, my problem is that half the screen blacks out entirely and the other half flickers when you move the mouse. If you stop using the mouse, the entire screen blacks out. Everything seems to be working normal in the OS in the background. Any one seen this problem before? Might be the graphics card maybe? I has happened 3 times the last 24 hours.
I put a video here:
https://youtu.be/zUuBVegNvo8
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
To figure out what your exact model is, look at the bottom of your stand foot to find the serial number plug it in here: EveryMac - Lookup
さんによる
コメントを追加
2件の回答
ベストアンサー
Your display assembly is damaged! I’ve seen this a few times.
I’m suspecting someone took off the display incorrectly and damaged the unit in the process. Sadly this will require a new unit:
  • [リンクされた製品が存在しない、もしくは無効: IF174-036]
  • [リンクされた製品が存在しない、もしくは無効: IF174-037]
You’ll also need this kit: [リンクされた製品が存在しない、もしくは無効: IF174-005] and you’ll likely need a few of these Plastic Cards
Here’s the IFIXIT guide to properly take the display off and to apply the adhesive strips on the new one iMac Intel 27インチ Retina 5Kディスプレイの交換
Plastic Cardsの画像
製品
Plastic Cards
$2.99
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
I suspect you are correct about the root of the problem, BUT it has not been opened before. Could it be that a problem with the display "just happens"?
さんによる
Basically the display controller board located on the top edge of the display got damaged. Take a look at Steps 5 & 6 in the iMac Intel 27" Retina 5K Display Teardown.
What I've seen is people use too long a tool which hits the ribbon cables damaging them. Here you might just have a bad display assembly. If thats the case (never opened) you should try getting it fixed under warranty.
さんによる
Yeah , I thought so too @danj, but its older than 1 year, so I guess it will cost me. Might be cheaper to buy a new display.
さんによる
I wouldn't throw the baby out with the bath water yet! Go to an Apple Store or authorized service center.
I think you still have a good chance getting it done under a 'warranty exception' but you need to press for it! Be polite but firm! You may need to work up the food chain, talk to the service manager and then the store and then the regional manager.
さんによる
コメントを追加
I do not have a Mac.
but yes it can be the graphics card. It could be an os corruption. When you power it on,is the screen black?
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
To determine if I a Mac has a actual display problem or the GPU is defective, I hit cmd-shift-3 to make a screenshot while the flickering etc. is happening. If You see the errors on the screenshots, the GPU actually rendered the picture wrong and it's a high chance it's defective. If the screenshot is clear it looks like the GPU renders correctly, but the screen doesn't display it correctly.
さんによる
コメントを追加
回答を追加する
peterhso さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,387
