メインコンテンツにスキップ
2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
Is there any known way to test Mag-Safe adapters
I’d like to be able to tell if I have a bad Mag-Safe adapter or if I need to look at the computer. I know they fail, as I have a box full of failed ones. It would be nice to tell first if my power source is working correctly. Anybody know how?
You would think there would be some type of testing software.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
There has to be a way to test them with a multimeter.
さんによる
You can check out https://en.wikipedia.org/wiki/MagSafe#Pi... and test the pins with a meter. Note how it says that the V+ should give full voltage with a 40 kOhm load.
さんによる
コメントを追加
1 件の回答
ベストアンサー
I just use a DC-In Board which I wired in a .5 watt 50 Ohm resistor for a load and then wired in test leads for both the power and the one-wire comm connection. Most of the time I just depend on coconutBattery output.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
mayer さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 11
今までの合計 7,725
