メインコンテンツにスキップ
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99回答 すべてを表示
Apple Cinema HD 23" Display stoppped working
The display completely stopped working without any indication that it was having trouble. I tried switching power supplies. I have tried switching where it was plugged in thinking that it was my video card. The USB or Fire wire ports are not functioning either.I have found the disassemble guide by apple but I do not know what is wrong or where to get the parts. Any help would be greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
To completely stop like that it would seem to me you have a power problem somewhere. Since you have a disassemble guide you should open up the display and look for obvious signs of damage or loose connectors. If none are found you should take a multimeter and track the voltage coming in to the point where you lose it. This should give you an idea of whats wrong. Let us know what you find and we will try to help you solve your problem.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Chris Van Arsdale さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 4
今までの合計 4,554
