メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Battery is not being charged while it says charging
I had repaired the charging port on my iPhone 6 after it had been damaged along with the screen. Everything worked perfectly for about 2 months, but then randomly stopped charging the battery even when it said it was charging. Is this a battery issue? The battery had been dying very quickly for awhile now.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Unfortunately trying to replace battery, after you replaced the lightning port, is the only attempt left on a DIY basis to see if the issue gets solved, but from your description there might also be a good chance there’s a logic board problem. Besides the bad hit, have you used uncertified chargers/cables to charge your iphone ?
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I'm assuming you're right about the battery being the issue based on other research I've done. If this were to be a logic board issue though, what would you recommend?
さんによる
@kaiserjesse If it was a logic board issue, the only real option you have is to find a lab specialized in microsoldering for repair. Boards for replacement market is limited and not cheap either.
さんによる
コメントを追加
回答を追加する
Jesse Collins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 36
