メインコンテンツにスキップ
Repair guides and support for your LG TV.
1342回答 すべてを表示
Black screen but have sound
Tv went black whiles watching it but still have sound.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@colie
we need more information from you. First we need to know the exact model number for your TV. When your TV is with a dark screen but you have sound, shine a flashlight at an angle against the screen. Let us know if you can make out silhouettes etc. If so it’s your backlight. LG seems to have issues with their backlight trips. If not, then you want to go ahead and disconnect all the video inputs and the power outlet. Then hold the power button down for 30-60 seconds. Connect one video source and the power plug. Then try and see if it restarts. Try all the video input sources as well. If that does not yield any change, it may be time to remove the back from your tV and take a look at he boards for any obviously damaged components. Post some images of your boards with your question. that way we can see what you see. iFixitでの質問に画像を追加する方法
You’ll need at minimum a multimeter to check out the boards etc. Let us know what you find.
このアンサーは役に立ちましたか?
スコア 9
コメントを追加
Your Screen Has Died
このアンサーは役に立ちましたか?
スコア -2
7 件のコメント:
@enderifixit how did you diagnose that?
さんによる
I doubt it, probably a capacitor.
さんによる
@oldturkey03 Maybe instead of focusing on other people's answers, focus on your own? I mean, it's the person who asked the question who gets to decide if it's an acceptable answer/diagnosis or not. Not you. Just saying.
さんによる
Technical Difficulties you are absolutely right. I do not see anything to the contrary nor do I see where I did not focus on my answer. I am obviously not as observant as you so maybe you can help me to understand where your comment is coming from.
さんによる
@enderifixit That's the job of a moderator.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Nicole Howell さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 918
