iMac 24, 2007, black display, though it projects to second screen
Hi,
I bought a used imac 24”, late 2007, EMC 2134 (imac#2). It worked for a few days and then I get a black screen.
When I am starting the imac, I hear the starting sound and fan but I always get a black screen. All 4 indicator LED lights are lighten. I tried and reset PRAM, change battery, remove all external devices and keyboard and unplug it for a while but nothing work. I also used a flashlight and lighten my screen trying to see my desktop but I didn’t (in case that was a back light issue as some people on the web stated). Then I connect it to an external screen I can see my desktop on the external screen.
I have done some research on the web and I see that there are a few more things to try:
a) replace the inverter board
b) connect with a wire two specific parts, inside the imac, in order to give to the display the message to turn on
Do you think that any of these suggestions would might fix it? I would appreciate if you have any other suggestions of what I have to try in order to make it work.
I want also to mention that I have also one more imac 24”, late 2007, EMC 2134, that I had bought as new back in 2007 (imac#1). I also had a black screen on this. A technician told me that I had to replace the screen, another one told me is the graphic card. Only the three first LED indicator lights are lighten. Then is when I bought the imac#2. So I can take parts from the imac#1 and place them on imac#2, if it is a need.
I also tried both displays in both imacs but I still getting a black screen in any combination (with imac#2 with all 4 LED indicator lights lighten and imac#1 with 3 first LED indicator lights lighten).
I am not experienced with electronics’ repairs but I will give it a try.
Please let me know if you have any suggestions.
Thank you,
Thodoris
Regarding the inverter, I tried to replace it but I didn’t manage to take it out completely as it has a blue “cord” connected to the inverter board and it looks like that I can not “unplug it” somehow.
この質問は役に立ちましたか?
